Its hard to work out without looking at your cables. I assume the problem started when the freeview box got set up. I would guess that the aerial cable is now in the set top box instead of the vcr as the vcr sounds like it is unable to record when there's no signal (a common feature) so there shouldn't be a fault with the vcr,
just unplug the aerial from the set top box & plug it back into the vcr. Ch 1 2 3 4 should be back on vcr but set top box wont have any Ch.
most set top boxes have an aerial output, so you'll need another aerial cable, plug this into the aerial input on the vcr & ch 1 2 3 4 will be there but these will be analog (if your area has stopped analog transmission thats the prob rite there)
If you plug the matching cables from the set top box into L1 on vcr you'll be able to record digital tv as L1 use a signal from another tuner eg set top box, dvd player whereas the vcr channels 1 2 3 4 use the vcr's built in analog tuner. so it shouldn't be a biggie another cable should fix it,
Hope this is helpful, ask if you need more info
