480/720/1080 is a function of the XBOX not the TV. The TV cannot change the resolution. The resolution indication that shows on the TV is only what it is recieving, not what it is showing, You need to check the XBox or whatever you are using.
The Green Line on the other hand is a defect and if the TV is in warranty you should make them fix it!!! That is unless this green line only appears with a single source....it should show ALL the time.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is: 1)unplug the TV completely, no wall no power strips, completely 2)wait 10 sec 3)plug TV back in and Turn it on, the light will still be doing the same thing 4)wait 30 sec 5)ON THE TV, not the remote, locate the menu, volume (-) and power button. 6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec. 7)on the remote control, go to menu>settings>system info *** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions*** 8)press the mute button on the remote twice 9)unplugg TV again and wait 10 sec. 10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
