My amana side by side, not sure the exact size but its fairly big and has front water and ice, is not getting cold enough on the fridge side. the freezer side works fine. fridge is kinda cold but not nearly enough. happened seemingly overnight. we cleaned and vaccumed the coils we could find. any ideas?
hello. I am assumming that your model has the ice and water dispenser. Not all models do. On the rear of these models with the ice and water feature you will find a small [1/4 inch] line that has to be connected to a cold water supply source. If you go to most any hardware store you can get the little kit necessary to make this connection. The kit consists of a length of 1/4 inch tubing, the connector to attach to the tube at the rear of your appliance, a valve and a tapping kit to tap into your closest cold water source. If the fridge is near the kitchen sink, you may choose to connect under the sink. If not, make sure you purchase a kit with enough 1/4 inch tubing to reach your nearest cold water pipe. J.
probably defrost heater is not functioning because it is no good or the defrost timer is not turning on. If you find ice in the back of the the freezer that would indicate the the heater is not functioning. Defrost the ice. Unplug the fridge. remove back panels and take off the two wires the heater coil. With a multimeter the coil should have a reading. Not sure exactly but should not be a large or open number.
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through
it.There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp.
You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck. Len West
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
First of all the worst thing you can do is set your fridge on the highest setting even though it has it. That's live reving your car to the red line just because it has it. As far as your challenge is concerned, it sounds like a breach in the seal of the fridge or dispenser. Check to see if the ice despenser is closing properly after use and check the door seal to make sure it's closing tight when the door is closed. To do this, simply inspect it for any bad wrinkles, cracks, folds, etc. if none are visible close the door on a dollar bill and make sure it holds securly all the way around the door. I f it doesn't, the seal may need to be replaced and/or the door is warped. If you continue to have issues, post again, we will work this out.
Sounds like the ice maker is overfilling.
You can adjust this by pulling the square front cover off and you will see a screw that shows ice size above it,just turn that screw towards the minus symbol.If not, post back and we'll go from there.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
