If you're finding grease under the washplate of your Whirlpool top load washer, it's likely that the transmission is leaking. The transmission is responsible for turning the drum during the wash cycle, and if it is leaking, it can cause grease to build up under the washplate. Here are a few steps you can take:
- Check the transmission oil level: The first step is to check the oil level in the transmission. If the oil level is low, it could indicate a leak.
- Check for leaks: Look for any visible leaks coming from the transmission. If there are leaks, it's best to take it to a qualified repair technician.
- Clean the washplate and drum: Clean the washplate and drum with warm soapy water and a soft cloth. Be sure to remove any debris or buildup that may have accumulated.
- Check the transmission oil seal: the oil seal may be the cause of the leak, if it's damaged or worn out, it will need to be replaced by a professional technician.
It's important to keep in mind that the transmission is a complex component, and if you're not comfortable working with it, it's best to consult a professional technician for further diagnosis and repair.
It's also important to note that some of these steps require a certain level of mechanical knowledge and experience. If you're not comfortable with checking these items, it's best to consult a professional repair technician if i was able to help my cashapp $ralphpapi thank you have a blessing day
