LG WM-1832C Front Load Washer Logo
Posted on May 17, 2017
I have an LG WM1832CW. Machine wont drain and
I have an LG WM1832CW. Machine wont drain and has an OE message. I noticed the pump is not turning on and I cleaned all drain hoses and filters. I removed the pump and bench tested it and it works fine. I metered the power supply to the motor and started the machine to drain and there is not voltage there. I believe it is a relay on the main board or something else with the board. Is there anyway to check this and repair a board. Its probably a relay and Id hate to buy a new machine for the cost of a $5.00 part.
5 Related Answers
Anonymous
  • Posted on Nov 30, 2008
SOURCE: LG WM1832CW Drain Pump
i drained it first with the pull out hose in the access panel on the bottom left. i tilted the washer back to remove it from the bottom.
Anonymous
SOURCE: drain pump on my LG
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Anonymous
  • 6784 Answers
  • Posted on Jun 21, 2009
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Anonymous
  • Posted on Jun 24, 2009
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Mar 13, 2010
SOURCE: my lg wm1814cw has a code of OE witch says to
You probably have an object in the pump or a bad pump
See page 27
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
My similar washing machine gives an OE error. It washes but won't spin giving the OE error. Please help
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter..... please clean drain hose back side of washing machine.. Thank you
Wont spin keeps coming up with oe on screen what does this mean
LG washing machine error code OE. Error code OE on The LG washing machines simply means the pump is blocked. Presumably the water isn't being emptied properly you might have something blocking the pump.
https://www.youtube.com/watch?v=JBCodfFo6Bc&vl=en
https://www.youtube.com/watch?v=KixjQQdGNF4
https://www.youtube.com/watch?v=A4ENzr2ZR1c
2helpful
2answers
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
What do we do after replacing the pump on an LG frontload washing machin, yet still get error message OE?
Assuming you cleaned the pump strainer?
Likely the drain hose leading from the pump to the drain, the section
inside the cabinet that "u-turns" back down is plugged up with
junk.. I had to remove the hose from the machine and force water
thru it at a outside faucet to clear what looked like a turd from the
inside of the drain hose..My shop vac could not dislodge it..
1helpful
LG wm1832CW Front load washer , error code OE and shut down, drain cleaned pump ok, ?
Yes, could be that the pump has dropped down on the efficiency.
check this link for tips to reset or rework the pump
Click on Pump
Oe drain error on lg wm1832cw washer: I replaced the drain pump, it still did not correct the problem.
OE - "No Drain"
Simply means the pump is blocked. Locate and clean the filter
Lg wahser wm1832cw flashes oe on readout. nothing in drain
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
2answers
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
4helpful
6helpful
OE message on our LG WM1832CW washer
I just was searching for the same exact error on my LG WM1832CW washer. From reading the other posts on different manufacturers I realized this was a pump clog issue for mine too. There is a small door near the bottom of the front of the washer and if you open that there is a filter basket. Once you start turning it and break the seal, the water will come out quickly, have 2 flat large tupperwares so you can catch the water. Once you clean out that filter it's good to go. A 5 minute job.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
