Question about Kenmore Refrigerators
I have a Kenmore Elite bottom freezer refrigerator. Model # 795 7105 and the freezer is not working properly and ice machine is not making ice. The fan and compressor are running. Did all the trouble shooting in my little service handbook. What else could it be?
6ya staff
SOURCE:
Anonymous
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
Anonymous
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    Bruce Hathcock
    • 3600 Answers
    SOURCE: kenmore elite bottom freezer icing up
    if it has an ice maker fix or adjust the over flow for the ice try.
    Posted on Jun 18, 2009
    blueextc3221
    blueextc3221
    • 15935 Answers
    SOURCE: MY ICE MAKER WON'T WORK
    This is an error code for the icemaker fan motor.
    If the control does not see a signal coming back from the fan motor you will get this error code.
    Please see the image below from the service manual that explains the ER IF error code.
    http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
    The ER IF code indicates a failure of the icing fan.
    You may notice slower ice production but the other fans should be okay.
    You can select the ultra ice option and see if the fan toggles on.
    The fan or the control is bad.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Posted on Sep 25, 2010
    blueextc3221
    blueextc3221
    • 15935 Answers
    SOURCE: Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
    Look for a lever to select cube size right on the icemaker.
    Posted on Sep 30, 2010
    May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice maker not working
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    fdfdfs43
    Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Icemaker not working on a Kenmore Bottom Freezer
    if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
    Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Refrigerator was making a 'Thump'' noise every so often and just stopped working. Freezer is still working It's a kenmore elite 3 door bottom freezer refrigerator model number 76539
    Unplugging for an hour won't allow it to defrost if that is what the problem is.
    Look inside the freezer at the back wall. Look for heavy accumulations of ice building on the cooling coil, which is behind the back wall panel. You may have to look in the louvers or past where the evap fan is located.
    Once we know if there is heavy frost or ice there, we'll have a better idea how to resolve. Is there any warranty on this refrigerator that you know of, besides the 5 year compressor warranty?
    Dec 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    My kenmore elite side by side is making a buzzing
    The buzzing noise is likely coming from the main power board and will need to be replaced.
    Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Kenmore elite fridge. Bottom freezer ice builds
    You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
    Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Er dh ken bot.fridge. 795.77552600
    one thing to try first is make sure there is enough air flow in the freezer and that the airway between the freezer and refrigerator's is free and clear
    Mar 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Refrigerators Logo
    64 people viewed this question
    Top Kenmore Refrigerators Experts
    Jimmy
    geob91
    John Tripp
    John Tripp
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
