I have read several threads and understand that problems may be related to the convergence ICs and associated resistors. Where would I find the repair kit for my particular TV?
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use
the inner RGB box pattern.
(1)Set
the [SLEEP TIMER] key to 0 min.
(2)Press
the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press
the [9] key to display the RGB box pattern.
(4)Select
the R mode by pressing the [DISPLAY] key.
(5)Adjust
the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select
the B mode pressing by the [DISPLAY] key.
(7)Adjust
the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check
to see that the cross pattern is white. If thecross pattern is not white,
readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
