Washing Machines Logo
S
Syluvia Ellison Posted on Jul 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My door on my Bosch 500; 2 month old washer won't unlock
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Sep 27, 2019
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
206189
Points
1556
Go back to the place you bought it,it still under gar-ante eric992
5 Related Answers
Anonymous
  • 183 Answers
  • Posted on Jul 30, 2007
SOURCE: Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Anonymous
  • 2605 Answers
  • Posted on Apr 26, 2010
SOURCE: can you tell me where the emergency latch is to
Hi, the emergency latch release is behind the small round panel below the main tub door. A string will be threaded through the pump housing and you just need to pull it to open the main door. To open the access door ( small round panel ) you'll require a small round needle shaped object or really narrow screwdriver. Put it in the small hole in the panel push in slightly and turn to about 6 o'clock...clockwise that is. The small round cover should now come off and expose the pump with the string going through a hook on the pump housing. Let me know how you make out and also if you require further assistance with this problem. Good luck. Macmarkus :)
Anonymous
  • 414 Answers
  • Posted on Jul 12, 2010
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Anonymous
  • 2605 Answers
  • Posted on Sep 12, 2010
SOURCE: I have a bosch next 500 series washer and the door
Welcome to FixYa.
Based on your description, "the door will not open. I have tried running the drain cycle and that doesn't work either" ...there is likely something obstructing your pump/filter hence the door cannot open.
With bosch as with most front-load machines, if the pump is blocked or the unit doesn't drain sufficiently, the door will not unlock.
Anyway, here`s the most likely way to remedy the non-drain and manually unlock the door issue.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( if it's too tight it can be turned by pliers...gently )
**DOOR RELEASE** you'll see a green ring attached to the pump, if you pull this the door should unlatch, but if the unit has water in it, getting it out first is usually a good plan )
5. There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.
6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap.
7. After inspecting for any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
**Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks**
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
Regards,
Macmarkus :)
Anonymous
  • 121 Answers
  • Posted on May 08, 2011
SOURCE: ge front loading washer door won't unlock
I had the same problem. I didn't want to spend the money or go to the trouble of replacing the whole latch assembly with the GE latch repair kit.
I found that the plastic latch piece screwed to the door had broken and one of the two latch "fingers" was stuck in one of the latch openings on the washer. I fixed the problem by removing the broken part from the washer and drilling and countersinking very small holes (1/16" I think) in the plastic latch piece on either side of the "latch finger". I then put the broken off piece back in place and drillled pilot holes for #4 sheet metal screws in the door where the latch is located. The door liner is plastic and I think I used a 1/32 inch drill bit. I reattached the broken latch piece with two 1/2 inch stainles steel #4 flat head phillips screws from Home Depot. The screws hold the broken latch piece in place as orinilally positioned.
The repair is working fine and the door now latches like it did before the latch part broke
Or: http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=2045520&pn_=WH10X10002 Same part cost $200 direct from GE
Read more: http://forum.appliancepartspros.com/washer-repair/8379-ge-washer-front-loader-door-wont-stay-latched.html#ixzz1LmNUKfTN
My Bosch 500 next washer has a error 4 code
something could be stuck near the impella that drains the water..need more advice send me a message
2answers
1helpful
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Bosch Washing Maching Model: WFMC5301UC Door won't unlock. No water going through the cycle
It might be defective door lock or defective control board or defective control panel and more over could be defective pump
Error message E27 appears and washer won't operate.
E27 means there is a problem with the door lock. Unplug the machine for 5 minutes and try again. If the error code returns you will need to replace the door lock assembly.
If you have anymore questions please comment me back.
2helpful
2answers
Bosch 500 series front load washer less than 6 months old. Getting code E27 when turning it on... suggestions before I call service?
Unplug the machine for 30 minutes and try again. If the error code returns you will need to replace the door lock assembly. Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Replace the door lock assembly on the washer. Refer to your washer manual for the correct part numbers.
Check to see if your Bosch washer is still covered under warranty. If so, you could receive free replacement parts and service for the faulty door locks.
Hope this helps (remember to rate and comment this answerr).
1helpful
Have a Bosch WFMC 3200UC and gives a E04 error.
In order to unlock the door on this machine you must first turn the cycle knob to a cycle that was different than the one you were on. The machine should then reset and the door should unlock.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
