Electronics - Others Logo
Md Abdullah Al Mamun Posted on Jul 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Suddenly my new pendrive not detecting with any computer. its a small still body pen drive. How to fix. Note sometimes it detect but not formatting or opening ?
Mike Daniel-Keehn
Level 2:
Habit-Forming:
New Friend:
  • Expert 27 Answers
  • Posted on Jul 14, 2019
Mike Daniel-Keehn
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
27
Questions
0
Helped
18400
Points
101
5 Related Answers
Anonymous
  • 28 Answers
  • Posted on Jul 24, 2009
SOURCE: sandisk pen drive cruzer 2gb not detected by the computer
first insert your sandisk pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Anonymous
  • 6 Answers
  • Posted on Aug 21, 2009
SOURCE: sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Anonymous
  • Posted on Feb 24, 2010
SOURCE: Pendrive detected but stil cant open
possible driver for pendrive is lost due to virus
try format the pendrive
Anonymous
  • Posted on Mar 23, 2010
SOURCE: pen drive detected but unreadable
BEST SOLUTION FOR UNREADABLE DISK IS TO FORMAT IT USING THIS WONDERFUL TOOL, I GOT SOLVED MY PROBLEM, TRY IT .
http://hddguru.com/content/en/software/2006.04.12-HDD-Low-Level-Format-Tool/
Anonymous
  • 1768 Answers
  • Posted on Apr 20, 2010
SOURCE: 4 GB sandisk pendrive can't open
1. continue without solving
2. If you didn't remove the drive with the safe removal tool in the task bar ( lower right hand corner) the drive will lose it's ability to be mounted or seen by Windows and will not format. You will lose data.
When i am join my transcent 4GB pendrive to computer then it detect properly but when try to open pendrive then disply msg "insert disk"or"format ur disk....plsease suggest wat can i do....
It's possible it's defective. Try to choose format. May fix it. (Lose everything saved on pen drive) Do not use "Quick Format" Do full format. If it fails format, then pen drive is bad. Discard and buy another for $5 - $10
2answers
My 2gb pendrive not working it is not detected
Trouble:
You may have faced a problem when you insert your pen drive and it gets detected very easily but it doesn’t show up as a drive icon in My Computer. The Computer detects the pen drive but data on pen drive is not visible as the pen drive is not visible in My Computer (Explorer).
This problem occurs mainly when windows XP fails to allocate a drive letter to your portable drive(pen drive). It occurs mostly with new pen drives connected to your computer for the first time. If you face such problem then it may not be the pen drive’s fault, rather it may be windows trouble.
If Problem Fix:
Fix:
You can fix this issue by following some simple steps given below.
1. Click Start, click Run, type compmgmt.msc, and then click OK.
2. In the console tree, click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. Now a assign a new drive letter which is not being used by any of your drives in My Computer.
5. After assigning the new drive letter your portable drive will show up in my computer with other drives
1helpful
3answers
I removed my pendrive without safe remove and its next ady onwards i am not able to detect my pendrive can anybody suggest some remedy??
Assuming that you are using windows, go to drive management and see if the pendrive is detected.
If so, right-click on it and format it.
Or look for the HP USB Disk Storage Format Tool and use it.
2helpful
2answers
Sandisk 8gb pendrive not detected
Pen drive is not detected
Check your pendrive in other PC, if same problem is seen, then your pendrive is over. & if it is detected in other PC then, your PC needs to install new OS. This will fix error for your pendrvive
Sandisk pen drive cruzer 2gb not detected by the computer
2answers
Try to insert it in every usb on your pc maybe its your usb port the problem!
211helpful
17answers
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
74helpful
8answers
Problem detecting transcend pendrive
On opening my pen drive it displays "Pl insert a disk in drive G
95helpful
12answers
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
