Question about Amana Refrigerators
Amana refrigerator ABB2224WES3
How do I take out the bottom freezer shelves
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
Mark Egan
  • 1214 Answers
SOURCE: anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 16, 2009
Anonymous
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
I have an Amana ABB2527DES and the bottom freezer door is not closing tight. Any suggestions?
Inspect door seals for shifting, bunching, and tears and adjust or replace them. Inspect shelving in compartment to make sure of proper positioning. Inspect door baskets for item protruding over the top and holding door back. Inspect door for loose hinges allowing doors to sag.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Aug 20, 2017 | Amana Refrigerators
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
Jul 06, 2011 | Amana ABB1927DE Bottom Freezer...
I need shelves and bins for the refrigerator part of my unit. Where can I get these locally in Sherman Oaks/Van Nuys?
can be ordered from amana ( through your local parts dist like marcone / very costley. . they don't come cheap .. mm hope this helps . mm feed back pls ..
Oct 21, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I need to replace one of the glass shelves. ANy
Personally I would check with one of the many places where people drop off thier old appliances first.(cheapest solution)
Then I would try an appliance repair shop. (second cheapest)
If they don't have the right size of glass you could try contacting the manufacturer.(probably the most expensive solution)
Hope this helps.
www.partselect.com/Amana-Refrigerator-Parts.htm
www.apwagner.com/index.php?main_page=page&id=67
Oct 04, 2009 | Amana ABB2527DES Stainless Steel Bottom...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana AB2225pekw
One of your doors is not closing all the way allowing warm air into the fridge causing condensation.
Sep 30, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
