Question about Kenmore Refrigerators
Kenmore bottom freezer refrigerator 596 the freezer is not freezing foods
6ya staff
SOURCE:
Anonymous
  • 237 Answers
SOURCE: side by side freezer
Check that the freezer circulating fan is running. The frige section may have dampers or vents (lets the freezer air cool the refer section) that are open too much. Usually the bottom area in the frige has a control lever to meter how much cold air gets to that section (lots for meat, little for fruits, etc.). Check the owners manual for operation of those vent dampers.
Posted on Nov 09, 2006
douglas smith
  • 1462 Answers
SOURCE: kenmore elite bottom freezer 596 serires
+4 degC for fridge and -18degC for free3zer
Posted on Sep 07, 2008
Anonymous
SOURCE: water leaking into bottom of
Drain hose clogged. Removed rear panel and blew out hose. draining fine and no water leaking into bottom of freezer or floor. Be sure to thaw out drain and tray before you return to service.
Posted on Sep 15, 2008
kram26
Mark Milan silaran
  • 544 Answers
SOURCE: My Kenmore fridge, Model 596-58692890
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 24, 2009
Anonymous
SOURCE: Kenmore refrigerator freezer not freezing
The problem is in the defrost system.. You have a defrost heater in your freezer that comes on 3 times a day & melts the frost to keep your freezer frost free. That frost turns to water & runs down a drain & eventually goes to a drain pan located under the unit. On these models the hole for the drain is located directly under the evaparator fan. The drain hole is to far from the heater so the water settles & then freezes around the fan blades causing it to stop spinning. Its that fans job to circulate cold air from the freezer to the fridge, so now all the cold air is staying in your freezer. Last I knew they were workin on a solution to this but you need to contact the manufacturer. A temporary fix would be to unplug & then defrost the freezer by taking out the freezer panel & melting all the ice. Boiling water is effective. When you get the ice gone from around the fan you should be able to see the drain hole & be sure water runs freely down the hole. Put it back together then adjust the front legs of the fridge so the whole unit slopes back slightly causing the water to run back to that drain hole without settling.
Posted on Apr 27, 2009
My freezer is keeping my food frozen,but the fridge part is warm and not cooling my model no is 596 69272993 it is a bottom freezer. What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Kenmore Refrigerators
We have a Kenmore Elite Trio (bottom freezer- Model#596 73502201-bought 2004) and both the fridge and freezer are blowing cool air but not cold. Food in freezer has defrosted and the fridge temp. is much...
Check to see if the evaporator behind the back metal cover on the freezer side is all frosted up, if it is, then it will probably be the defrost heater which is bad and letting it clog with frost causing low or no airflow. The heater is not expensive and can be ordered online on ebay.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 02, 2018 | Kenmore 73502 / 73504 / 73509 Bottom...
Have a kenmore elite bottom freezer that is not
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
Apr 23, 2010 | Refrigerators
The refrigerator makes a popping sound
sounds like it's your self-defrost working normally as for things freezing,check temps in front and back of refrig and you may be able to raise temp to alleviate condition w/o food in frt end being too warm
Aug 18, 2009 | Refrigerators
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
thanks,
Mar 24, 2009 | Kenmore Refrigerators
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore freeze on the bottom.. model 596-72219200
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
