SOURCE: valve cover gasket oil leak into spark plugs
you will have to put another valve cover gasket on between each cylinder there is a round gasket between valve cover and cylinder head if you buy the valve cover gasket kit they will be in the kit .please rate this answer thanks.
SOURCE: car starts, won't stay on after added oil.
If you happend to open the door or unlock from the inside. you might of activated the theft shut down alarm. Try unlocking and locking the driver door a couple times then taking your key phob, lock and relock the doors until it armed. unlock it then see what happens
SOURCE: Leaking air
If the unit is leaking air you must install an O-ring kit. The correct on for this model is an ORK-6. Any Bostitch service center will have these kits.This should solve all the leakage problems
SOURCE: crown vic oil change
Some of them have an oil plug at the front of the pan, as well as the regular one. You have to drain them both. The front one only holds a quart or less.
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
