On the Makita 18-V DC18RA charger, the flashing red light means that the battery is not at the correct temperature for safe charging. If the battery is hot (from use or being in direct sunlight), charging will begin when the battery cools down. If the battery is cold, then charging will start when the battery warms up. (Note: the cold battery could have moisture condensation issues. This could delay the start of the charging cycle.) Home Depot has the manual for this charger here: https://images.homedepot-static.com/catalog/pdfimages/35/35393127-7c0b-4668-8609-9104ae7cc187.pdf . I suspect that Makita uses the same "code" on all of their chargers.
I hope this helps.
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
SOURCE: Need to know what the lights mean on a makita dc24sa charger
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
SOURCE: hi i have a makita charger that flashes red and
there is a problem with the charger and given the age I would take it to an authorized dealer and get a replacement. If you give me your general area I will try and locate one close to you. Please before voting if you need more assistance let me know. Thank you
SOURCE: Makita 18v lithium battery when put on charge
This isn't true because I have a second charger and it works fine
