SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
hi i have the panasonic combi and on the microwave it will work for a few seconds and then stop and on the screen it shows h98 please help
SOURCE: broken door catch, possible spring,
If
you gently push up on the door latches (hook-like devices on the door)
there should be spring tension. If they just flop right up, the spring
is off.
Normally the problem is not the spring, but a broken
spring mounting tab on the door latch head (hook) assembly or the inner
door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
SOURCE: Need nn-c988w Microwave manuel
http://service.us.panasonic.com/OPERMANPDF/NNC988B.PDF
hello , here is the manual for that model nn-988w / nn988b , thanks for voting FIX YA !
SOURCE: Setting time on Panasonic NN-CD748B microwave
Panasonic's UK site is here and you can choose Support, then search for spares, servicers, downloads and contact info.
We're
SOURCE: I desparatly need instruction for the NN-A554W
Apparently that's a UK model.
You can visit Panasonic.net, select your country, then follow the support links to find the manual download area.
If yours in not there, look for spares or service centers to order one.
We're
