The freezer is side is not freezing the whole compartment, only the bottom shelf. Same on the fresh air side, only the bottom drawer is getting cold. I have reset the defrost heater, and it helped some but still not getting all the compartments on both sides to their proper temperature.
Your model should have an Adaptive defrost control located inside the fresh food compartment. That is the most likely reason for your problems with your defrost problems. If you are able to reset that leaves me curious. To get the proper air circulation we will need to get the defrost working on time, and clean around the condenser below the refrigerator. Once the ADC is replaced the refrigerator should begin to operate more efficiently and these problems will resolve themselves as long as door seals and temperature setting may need to be returned to there normal settings. The part number for the Adaptive Defrost is Part Number 1036287 I will assist you in the repair if you like, Thanks, Sea Breeze
I would like you to unplug the refrigerator and remove ther rear panel in your freezer. This will expose this costly and timely problem you are having. I have a video on one website and the parts on another. The video shows what the evaporstor coils look like when they are not defrosted reguarly. The Adaptive Defrost Control also has part number 241508001 The short video is on the lower part of same page. Thank you sea Breeze
http://servicepartstec.blogspot.com/
