Question about Washburn Electric Guitars Modelno. X10-B
Candy washing machine smoke coming from inside
Candy washing machine CN105T.Smoke coming from inside drum after spin.
Drum seems to be rubbing on front rubber making flapping noise but only on spin mode.
When turning drum by hand the bearings seem quite smooth & the drum turns easily?
  • Michial Gueffroy May 11, 2010
    Try posting this in the home appliance category. It is in the musical instrument category and I don't think you are being noticed.
  • 34 Answers
It is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Posted on Sep 18, 2009
6ya staff
SOURCE:
Casiotone 403
it might still work for now. but the magic smoke is never a good sign when it comes to electronics.
i would open it and see what caused the smoke. any cracked/burnt components.,burnt leads on the circuit board or bulging or blown capacitors. if you then take a photo of the failed part(s) and upload together with a new question about it you will get a better and more accurate answer if its "safe" to use. and maybe even a fix for it
Oct 28, 2013 | Music
I need to know the correct way to play this drum machine through my amp.
If you have a direct out use that? You can also use the Headphone jack coming out. Make sure the volume on the DM is very low. And bring it up slowly.
Dec 27, 2010 | Alesis Sr 16 Stereo Drum Machine
Sound cutting out
You may be having early stages of arc over in the main amp. This leads to catastrophic failure of the power amp section (usually the rearward one) and sometimes the power supply.
Facing the back of theunit, usually the left speakon connector is the one that connects to the section that fails.
The arcing is between two layers of a multi-layer board.
Note, if you smell smoke or pop a fuse DO NOT continue to use the device but get immediate servicing.
Jul 10, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Got smoke from inside keyboard and diskette, hard drive and scsi no longer show as available on system screen. Am using midis from HD but can't view it when using disk utilities. I suspect a board is gone,...
Any electronic device that has smoke coming from it is not a good sign. Whether it can be repaired is debateable (it depends if parts are available and costs). Usually in cases such as this it needs a new circuit board and possible other associated components/devices. I suggest the best solution is to purchase a new Yamaha keyboard as a new model would have new and better features.
Nov 19, 2009 | Yamaha Portable Keyboard
Alesis-sr 16 sound low
Buy the correct adapter that matches the voltage AND current requirements of the unit. MANY universal ones do not and the original MAY have built in filter that universal does not.
You MAY also need to do a factory reset on the unit.
Oct 18, 2009 | Alesis Sr 16 Stereo Drum Machine
Can hardly hear it,seems like it's running @ half power.
go in to drum set, and set the volume for each drum
Oct 09, 2009 | Alesis Sr 16 Stereo Drum Machine
The Bass Drum Pedal of our Yamaha DTXplorer electronic drum kit has come to pieces. There are springs and washers everywhere and I don't know how to fix it. The instruction manual doesn't tell me. If you...
Go to one of the suppliers. Most of them will have photos of the bass pedal assembly and if you can enlarge the photo, you should be able to figure how to assemble it.
Expect to find washers on shafts between things that rub.
The owners manual at:
http://yamahadtxplorer.com/yamaha-dtxplorer-owners-manual/
Check on page 9 for example. While the photo isn't the greatest you can see where the spring is.
Sep 11, 2009 | Yamaha Music
Problems with DTXpress III special bass drum pad
If you are comfortable with working on it and the warrantee is up try taking the pad apart to see if the piezo element has come loose from its mounting or if the solder joint is loose. If that isn't the problem save your settings and initialize the set according to the instructions in your manual.
Aug 09, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
All seems working but NO sound coming out of any outs. I've initialized it and did all I can remember to get it up and running after a long rest... in other words, it's been in the cupboard for some...
If I remember correctly it will have a backup battery inside that may have died. You will need to replace it and download the correct patch to get it up and running again.
Feb 20, 2009 | Alesis Sr 16 Stereo Drum Machine
Washburn Electric Guitars Modelno. X10-B Logo
670 people viewed this question
Top Washburn Music Experts
Michial Gueffroy
David Gust
Bruce Showalter
Are you a Washburn Music Expert? Answer questions, earn points and help others
