Washing Machines Logo
V
Valencia Mert Posted on Jun 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Lg top loader wash and drain everything but dont want to spin...What can be wrong.
Dw Wooten
Level 2:
Sergeant:
  • LG Expert 227 Answers
  • Posted on Jun 24, 2019
Dw Wooten
LG Expert
Level 2:
Sergeant:
Answers
227
Questions
Helped
115638
Points
551
Could be lid switch are some else, you should call techicain to help you out
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on Jun 09, 2008
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Dissolu
Gintautas Maldzius
  • 221 Answers
  • Posted on Aug 07, 2009
SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Anonymous
  • 632 Answers
  • Posted on Oct 19, 2009
SOURCE: Hi my LG 8kg top loader washing mashine says UE
UE code means an imbalance error. Either the load is too small, the appliance is tilted, laundry is gathered to one side or a non distributable things are put into the drum.
Make sure the unit is placed in level location and distribute the load evenly inside the drum. Do not load the unit with on-distributable items.
Anonymous
  • 43501 Answers
  • Posted on Apr 28, 2010
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
Anonymous
  • Posted on Aug 10, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
1helpful
LG Fuzzy Logic 5.5 kgs top loader washing machine.
Question edited for clarity, add maker.
They are a funny little machine. The disc in the bottom is the agitator. My first thought was that you weren't locking the lid down properly, but if it spins, you are. Unfortunately, it sounds broken.
https://www.google.com/search?q=Fuzzy+logic+5.5+kg+top+loader
Manual
https://www.lg.com/au/support/products/documents/WT-H756.pdf
Lg top loader washes and drains but dont want to spin
call a technician to check the program board for problems
1helpful
Hi there ! I have a LG Top loader WF-T7030TP that wash the clothes but do not want to rinse,spin and drain the water.
you have blockage in your drain in the machine-possibly something stuck in the drain pump like a sock or a paper clip-tear it down-have a couple of old towels handy for the mess-cheers Denny
1helpful
My LG front loader works but wont spin WM1814CW model
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
12helpful
2answers
heatman101
5helpful
2helpful
3answers
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
