Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Nov 30, 2007
Ms word 2007 docs print every other line
Documents created in ms word 2007 will not print entire doc. Preview shows all lines, but when printing it skips every other line. Other docs (ie; Excel) print fine, so I don't believe it's a printer issue. Any ideas?
  • 1 more comment
  • ponyexpress Nov 30, 2007
    Isn't the driver updated when the program is loaded? Other print jobs work fine--Excel for example prints without incident. Normal print jobs are fine as well. I have a HP Photosmart 2610xi printer btw....
  • ponyexpress Dec 04, 2007
    Thank you Tallow....that did the trick. I did the whole uninstall and reinstall of the printer, and that solved the issue. Many thanks!
  • Anonymous Mar 17, 2014
    when ever i try to print a document it only prints header and fotter
Anonymous
Level 1:
Problem Solver:
  • Contributor 36 Answers
  • Posted on Nov 30, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
36
Questions
0
Helped
9199
Points
57
This seems like a print driver problem. You may have to get an updated driver for your printer for Msoffice 2007.
Sean
  • Anonymous Dec 02, 2007
    . Did you deleted anything out of your computer lately. You may have currupted the print driver. It might be worth uninstalling and reinstalling the printer, and log on for any new updates for the print driver when you install it.
2answers
I cant seem to open my attached docs nd it downlaod in note pad which make the docs come out as encrypted...Which microsoft office would be more suiatble for windowa 7?Please advise me which program i...
The problem is that your documents were created in older version of ms word now you need to open it up in xp 2007 which is not possible. You need to instal ms 2003 also on your machine so that you can open up older documents
5answers
HP Photosmart C7200. Printer is not printing the bottom quarter of the page, despite print preview showing the whole page fits within the margins. I am using A4 paper
Try reseting the printer to factory defaults- also does the same problem happen when you a printing from a computer or trying to print a scan directly on the printer?
try restoring the printer to factory default settings, you can also try reinstalling the drivers on your computer.
Printing only every other line in Word 2007 doc
Dear pony, it could be because you might have changed your print settings.
You can press CTRL+P to change settings
You might also select the text you want to print and print selected.
You can also format the text by going into formatting options of MS word.
This can be because you've put the number of copies to 2. Thats why its printing again. Change it to default and it should fix your problem
If that has helped you please press 'fixya'
16helpful
5answers
What is the meaning of X in the word DOCX?
The X stands for XML (Extensible Markup Language), which is the programming language behind the scenes in Office 2007 programs.
Previous versions of Word were based on binary data. Binary data is, by nature, prone to corruption, and "bloated."
By changing the background code, Microsoft was able to create new tools and features in Word 2007 that would not have been possible otherwise.
How do I fix canon mx310 which prints with lines
please check doc. page setup, may be outline or outside margin resulting not space.
Page Eject WHen Printing Word Docs
change the paper size in the printer properties for example to a4, or to lettersize.ehat the actual sizeis.or the problem is with paper feeder gears. try cleaning them.
HELP PLEASE
Most likely this is an issue with your print margins. Try changing the margins by making them smaller.
HELP
You may need to adjust your margins so that the bottom border shows. In other words, go to file> page layout>margins and adjust the bottom margin to a lower number, the check print preview.
If that does not work, try checking the border settings. Perhaps line weight has been set to 0 or color has been set to white or no color for the bottom, causing it to be invisible.
HELP PLEASE
maybe your printer is out of ink..
hope it will help thanks..
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
