On some occasions when the machine is filling it water comes from the bottom of the left hand side of the machine,
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Have you cleaned out your soap dispenser also remove and clean the inside of it ie top and bottom of the in side area
Check the intake valve on left hand at backside machine or
check the hose connection with intake valve
