My washing machine won't turn or spin.
My integrated Bosch washing machine WFL12440 won't turn or spin. The drum can be moved around manually without a problem. Before it stopped spinning altogether it was making erratic crunching sounds for several days.
    Sergeant:
    Champion:
  • 255 Answers
Ok on the bottom there is a donut looking connector with holes and it needs replaced unless its belt drivin
Posted on Aug 14, 2009
Anonymous
SOURCE:
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Bosch Nexxt 6400 has flopping drum-can move it back and forth while spinning by hand. Tech sez broken shaft gear--get rid of it.
this has had its day mate get rid of the machine as you can not repair as the drum is sealed on that model ok
Nov 03, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
The washer won't spin. I have one light blanket in the machine and it won't spin. I turned the machine to a regular wash cycle to see if the drum would spin and it did. When I turn in back to the spin...
Hello, Welcome to FixYa. What I'm going to tell you can be validated with the Bosch owners manual so I suggest you check into it. The reason the Bosch will not spin with just a single item (regardless of weight) is it isn't designed not to. If you add a similar garment of equal or similar mass it will spin. These units rely on weight differential to determine balance...if one side of the basket has too great a difference from the other, the dyno on the motor will not allow it to spin. Thank you for choosing FixYa today and good luck. Please let me know how it goes or if I can assist you in any manner going forward. Regards, Macmarkus :)
Apr 05, 2011 | Washing Machines
Bosch classixx 1400 express spin vibration problems - when my machine spins is vibrate violently and moves across the floor - how do i fix it?
Is the clothing distributer evenly around the drum or is the washed bunching it up and spinning it around as a ball.
Jan 16, 2011 | Washing Machines
My Bosch washing machine has a drum that no longer turns. When the cycle reaches a point where the drum has to turn, I hear a series of clicks and the spin does not work at all. I took the back off and the...
Check you can move the drum freely by hand. 1. if its free - then check belt. 2. if it wines - check motor. 3. if does not move - you need to check for obstruction. hope this helps ....
Jan 07, 2011 | Bosch WFMC 3200 Front Load Washer
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
The drum won,t go around or spin BOSCH Classixx 1200 washing machine
BOSH WFL 2260 SPINS OK BUT WASHING CYCLES DO NOT WORK. FILLS WATER OK
Sep 26, 2008 | Bosch Washing Machines
My bosch classixx 1200 express
Close the door and turn the dial to drain
Jan 11, 2018 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
329 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
