Hi Mary, go to batteryspec.com. In the search box put in TR2.6-12 even though it's 2.6, it equates to 2.8 for our spotlights. The battery is around $20 with a 1 year warranty, and has the same specs (dimensions, terminal position) as ours.
if you have the replacement lamp, look at the end that goes into the base, it it has flat tangs, you need to push in as you turn it counter clock wise, if it has pins you just need to pull on it it should come out
You'll need to dis-assemble to see exactly what broke. Most of the time, it is not worth fixing since it was dropped, something else will let go in the near future. Sorry.
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
The replacement bulb has the part number P361235WFL - H available to order through Wilts Electrical (in the UK) cost is £10 plus VAT (There is however a minimmum order value of £15) so it attracts a premium of an additional £3.50 plus VAT.
