Welding Tools Logo
Troy Kinkead Posted on Jun 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need wire diagram for Miller big 20 sn.jb505827
littlewheel
Level 2:
Loyalty:
Visited the website for 30 consecutive days.
  • Expert 122 Answers
  • Posted on Sep 16, 2022
littlewheel
Expert
Level 2:
Loyalty:
Answers
122
Questions
Helped
41931
Points
328
Tom Chichester
Level 3:
Top Expert:
  • Miller Master 62,329 Answers
  • Posted on Apr 17, 2021
Tom Chichester
Miller Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672477
Points
975369
Contact Miller directly to request the Big 20 wiring diagram.
3 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Oct 25, 2009
SOURCE: Need wiring diagram for switch on Cat #5378-20 SN
Go to Milwaukeetool.com and under service/manuals you can type in your model number and download the wiring schematic for this tool. If I have helped you with your request would you please rate this response accordingly and thank you.
Testimonial: "Thank you for the info."
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Jun 05, 2011
SOURCE: I need a wiring diagram for miller 502D starter
The manual is here:
http://www.millerwelds.com/om/o495an_mil.pdf
Wiring diagrams are on pages 68 - 79 of the file. It is best to print out the 2 diagrams you need and tape them together as they go across 2 pages.
Thanks for choosing FixYa,
Kelly
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jan 02, 2017
SOURCE: Why is the amp light staying on miller big 20
The battery is not being charged due to a failure in the alternator or the wiring.
2answers
2006 Miller Trailblazer Pro 350d wont weld or generate power , in startup it will jump to 80volts then immediately drop to 0 , if it's the voltage regulator where is it located on the machine? Thanks
See attachment, item 9.
Go to
https://www.millerwelds.com/support/manuals-and-parts.
Enter Model/SN and download owners manual. Diagrams and parts lists are in the manual.
Check all fuses with an ohm meter for continuity.
1helpful
Do you have a Diagram for miller big 40?
This may be useful;
https://www.manualslib.com/manual/103859/Miller-Electric-Big-40g.html
Need wiring diagram for aead 200-le miller charging system with stater under fly wheel
The wiring diagram for the charging system on a Miller Aead-200le Constant Current AC/DC Arc Welding Generator Gas Powered will be provided in the operator's manual for the machine. The manual will have detailed information on the wiring diagram of the charging system, including the connection and function of the starter under the flywheel.
It's important to refer to this manual for specific instructions and guidelines for the wiring diagram of the charging system. You can find the manual on the Miller website or you can contact Miller Electric and request a copy of the manual.
If you cannot find the manual or if you are not familiar with reading wiring diagrams, it's best to take your welder to a qualified Miller Electric welder repair service center, they will be able to provide you with the necessary information and help you troubleshoot the issue.
Welder wiring diagram
The number and location of connection points on a Miller welder when removing the welder and motor from its casing will depend on the specific model and year of the machine you have.
Here are a few things you can try:
  1. Check the manual of the welder, it should have a wiring diagram that shows the number and location of connection points on the welder.
  2. If you don't have the manual, you can find wiring diagrams for most Miller welders on the Miller website, you can download it from there.
  3. If you are not able to find the wiring diagram for your specific welder model, it may be necessary to contact Miller Electric and request a copy.
  4. If you are not familiar with reading wiring diagrams or if you are not comfortable working with electrical equipment, it is best to take your welder to a qualified Miller Electric welder repair service center, they will be able to provide you with the necessary information and help you troubleshoot the issue.
Please note that some models may have different ways of wiring, it's important to refer to the manual or consult with the manufacturer for further information.
I have a miller side kick wire welder ser. no. jgo79849 ware can i get wireing diagrams
Miller - Owners Manuals
There were a number of versions that bore that name. I rebuilt a board on one and found that out. Fortunately the differences were easily identifiable.
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
2helpful
Need wiring diagram for switch on Cat #5378-20 SN 897D705030452 Hammer Drill
Need wire diagram for Miller Syncrowave 250 DX
diagram is on the inside of cover or go to Millerwelds.com
Top Miller Welding Tools Experts
Sean Wright
Sean Wright
john h
Jay Finke
Jay Finke
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
