Washing Machines Logo
Dawn Bradford Posted on Jun 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Miele w4842 f63 fault. How can I fix - Miele Washing Machines
Dan Brawley
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 26, 2022
Dan Brawley
Contributor
Level 1:
Answers
Questions
Helped
1877
Points
George, did your your cleaning work and allow gears to mate/move parts?
Geir Lland
Level 2:
Habit-Forming:
New Friend:
  • Expert 146 Answers
  • Posted on Sep 10, 2019
Geir Lland
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
146
Questions
0
Helped
83696
Points
431
Water path control system faulty.
The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
You have to replace water intake system.
The top of the soap dispenser with pathway selector
3 Related Answers
bmohns
George Mohns
  • Posted on Mar 28, 2018
SOURCE: miele w3033 tech fault f63. what to do?
Same issue here with the Water Path Control Unit of Miele W 4840. No teeth broken on any gear, and the motor was trying to turn the gears, but the red gear was stuck. Found heavy buildup from hard water inside the rotating valve itself, and on the spring under the red gear. I think the buildup was preventing the red gear from lifting over the detents to the next position. I disassembled (be sure to first mark red gear and post as it can be reassembled wrong, and take care the spring doesn't launch the red gear and spring across the laundry room when you release the little clips holding the red gear) and soaked the spring and its washer in CLR (calcium, lime and rust remover, from hardware store) and swabbed the rubber and plastic pieces with CLR to clean everything. Greased gear teeth and posts, and rubber seals, with silicone grease and reassembled. Note the double-wide tooth on the red gear aligns with a double-wide gap on the matching white gear, the one with the spring contacts.
Anonymous
  • Posted on Jul 16, 2010
SOURCE: hi,i have a washing machine miele w 3000 tech
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
Anonymous
  • 6277 Answers
  • Posted on Mar 23, 2011
SOURCE: I would like a stacking
Sorry but this forum does not supply parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
Model W3370. What does error code F63 indicate?
Google does indeed know
Miele washing machine error code f63 F63 malfunction: too much foam
If so, there is too much foam in the drum and you may have used too much detergent.Jul 15, 2020
The top 6 errors of Miele washing machines - Coolblue ...
www.coolblue.be > ... > Miele washing machines Search for: Miele washing machine error code f63
I have a miele w4842 washer machine and it display fault.close the door and confirm with start.i did replace the inter lock switch but still not unlocking the door after the cycle finish
Unfortunately the Power control board on this is the fault - we have seen a few with this fault and it seems the relay that controls the door lock can be the culprit here
1helpful
Model No:Miele PW6065 F63 fault solution?? how to i solve my self, please give me some solution?? ts urgent
Miele f63 fault. I poured clean water through the soap dispenser drawer and tipped the washer at 45° several times and it's working now.
Fault F63
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
Hi my Miele W1712 washing machine is showing a F63 fault
The F63 is an error when something is blocking in the water path. I would suggest to open the front access drain flap and check for any objects like pins, coins etc. remove them and this should clear the error.
1helpful
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
2helpful
2answers
Hi,i have a washing machine miele w 3000 tech fault f63.what i can do?
Total Cost: (HKD)
1100 for the part
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
