Getting to the shock-absorbers
How do i get to the shock-absorber, would like to check if they are still in working order, the machine seems to vibrate while spinning.
thanks,
Ryan.
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Anonymous
SOURCE:
I have an lg front load washer and on the spin cycle it vibrates very loud and seems not to be balanced. Washer is level and does this regardless of load size
there are 3 shock absorbers attached to the drum. they may need replacing. check out the videos on either applicancepartspros.com or repairclinic.com
Mar 14, 2015 | LG Washing Machines
Machine has a bad vibration on the way to high spin, once there all is ok
The shock absorbers may need greasing, Put a bit of grease (the thick motor type) around where the smaller diameter part of the shock absorber enters the larger part, the take of the lid (isolate from mains) and give a a few hefty shoves on the drum downwards to help the grease to work in. Excessive knocking on the lead up to full spin could also be caused by an uneven load, the unit as a whole not being level or the unit being located on a joisted floor which increases vibration.
Hope this helps
Mar 27, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
"Shock Absorber" wear?
A lot of people convince themselves that the shock absorbers are causing the problem, but that is rarely the case. if you remove one of them, you will find that they are actually two pieces, and only provide some compression cushioning as the barrel moves around. a little bit of grease might help them a little. Do make sure that they are all connected and positively secured in place, as they sometimes look connected correctly but actually aren't, which can cause problems.
In my experience the problem is that the base, over time, begins to amplify the vibrations of the machine. It is after all, a top-heavy setup. Try putting the machine directly on the floor and see if that does the trick (get help, it's heavy)
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Vibrate when on spin
May 03, 2009 | Washing Machines
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash machine spinning off balance
Jan 01, 2009 | Washing Machines
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Sep 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Vibration
Is the machine level. The feet should be tightened and the nuts should be tightened against the cabinet. Tilt the machine back and check the shock absorbers. One of the shockies could have jumped out of the guides.
Oct 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
Washing Machines Logo
401 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
