Music Logo
Wayne Seims Posted on Jun 21, 2019
I need a schematic or circuit diagram for a Peavey PVi Portable PA..anyone? Thanks.
  • 1 more comment
  • Wayne Seims
    Wayne Seims Sep 27, 2019
    All sorted now, I got one from UK distributor, fortunately I had already managed to fix all the problems. Thanks
  • Bernie Scott Sep 27, 2019
    What were the problems...
  • Wayne Seims
    I think it was several points damaged on print along with a broken pin in one of the XLR input sockets. So I suspect it may have been dropped.
Doug Caskenette
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 25 Answers
  • Posted on Sep 27, 2019
Doug Caskenette
Contributor
Level 1:
Greenhorn:
Night Owl:
Answers
25
Questions
Helped
13486
Points
77
Did you try www.peavy.com
Bernie Scott
Level 1:
  • Contributor 27 Answers
  • Posted on Sep 24, 2019
Bernie Scott
Contributor
Level 1:
Answers
27
Questions
Helped
11605
Points
44
Have you tried contacting Peavey??
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Dec 15, 2008
SOURCE: Peavey 400SC
You can find Peavey's manuals in their archives at
http://www.peavey.com/support/searchmanuals/archived.cfm
They are grouped alphabeticaly across the top.
Go Fer' It,
FixThemAll.........
Michial Gueffroy
  • 1140 Answers
  • Posted on Jun 25, 2009
SOURCE: circuit diagram for a Peavey 130 special
Try http://www.peavey.com/support/contactinfo/ You may be able to get one from them. When I was doing repairs they would only release schematics to Peavey dealers but you can always ask.
Chris Taylor
  • 88 Answers
  • Posted on Feb 04, 2010
SOURCE: how do i connect the cables between peavey vocal
if you mean effects loop try graphic out to ultraverb input and output to power amp in. this will effect all channels of the xr500c
Fred Yearian
  • 5603 Answers
  • Posted on Feb 16, 2011
SOURCE: the power of the Peavey Escort 3000 Portable PA
A failure probably occured in one of the power amps and has blown the fuse or worse. DO NOT replace the fuse and try to operate it as further damage may occur. Take it in for repair.
Fred Yearian
  • 5603 Answers
  • Posted on May 24, 2011
SOURCE: there are some burnt carbon resistors beyond
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
Schematic for peavey standard pa mixer amp 260 series
Contact Peavey customer service at this link-
Peavey com
2answers
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Peavey PVI 8B
and the question is
The power of the Peavey Escort 3000 Portable PA Sound System went off while in use, and since then power is not showing any more
Could u please send me a circuit diagram of Peavey sp2 crossover with the exact rattings or values of the parts? cos the image of the bulb you have sent is different from the one in my speakers
Here is a link to forum that someone has posted the soundguard protection circuit down the page:
http://forums.peavey.com/viewtopic.php?f=26&t=2168&view=previous
The 1156 lamp MAY have slightly different shapes but is an automotive lamp. If the bulb is blown, the polyswitch fuse is likely blown as well.
1helpful
Circuit diagram for a Peavey 130 special
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
