Pull down shower diverted works, but allows much water to run out into tub during shower mode..... Can it be repaired ?
The diverter is supposed to leak a little bit, so it will disengage after you turn off the water. If the water is leaking out a little, that's normal. But if it is really leaking out you may need to replace the entire spout.
It can be repaired you have to take the faucet apart and replace the washers. Not hard to do you tube it I'm sure there would be a video showing you how.
