Connect to your router preferably with a network cable. login via your browser to http://192.168.1.1 using admin as both the login and password. Once logged in it should give you a message to change the password, but if not, you will easily find the location for making a password change. Just make sure you write your new password down so you can change it on every machine you wish to allow on your network.
you must need to put in more than the ppoe connection type, there is the vpi =0, vci =38, then input your isp's username and password to get a connection.
All this must be done via the RJ45 cable and making sure that the pc's lan card is set to obtain an ip address automatically.
To get into the routers settings, type into your web browser either 192.168.0.1 or 192.168.0.100, as i'm not sure that actuall routers address, sometims it's on the underneath or refer to the manual.
