SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
SOURCE: Feed dogs won't raise up again
The Kenmore is made by Janome. The Janome has a little cam (lever) that when flipped, is pushed out of the way so the feed dogs will drop down. Over time (read too long between thorough cleaning and oiling), the cam will stick over where it is pushed. It is physically pushed when dropping the feed teeth, but it when you flip the lever back, it relys only on a spring for it to pop back. It only has one spot in a complete hand wheel rotation to pop back, and if it sticks at all, it wants to stay down.
Solution:
Hold the feed dogs up while turning the handwheel. This can help it pop up. If that doesn’t work, remove the two bottom screws under the free arm and look for the cam. It like the on the very end of the machine even left and further back from hook. As you turn the handwheel, you’ll see it rotate as a lopsided wheel on the shaft. Gently push it right while you turn the handwheel. Then clean and oil it so it will move more freely
Kent
Solution:
Kent
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
SOURCE: Kenmore sewing machine # 385.17626
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
SOURCE: feed dogs stuck in down position
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
