Water accumulates in the bottom of frigidaire side by side frost proof freezer and freezes. Eventually it overflows and comes out the bottom of the freezer door. Actual model is F45ZR24J Side by Side Frost Proof refrigerator.from around 1999-2000 model year.
Take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
I had the same problem. I used chris72's solution and it appears to be fixed. Fingers crossed!
have taken trays out to discover a leak at the bottom of plastic tubing to the water reservoir. to retrieve water at the spout the reservoir connection on bottom side leaks as though it has a split at the base of the nipple. would like response to this problem and price of reservoir.
nothing stays cold or frozen. Both sides do not keep temperature. I cleaned alot on the back of the frig and left if unplugged all night and then re-plugged it and set the dials to factory settings and it all worked and ice was being made and then a day later it all began not cooling again on both sides.
I have the kenmore elite, model 596.73502203. The bottom freezer has frost and the light did not come on.
i have a Frigidaire freezer that keeps leaing water at the bottom
