Possible your outlet filter is blocked. This requires cleaning depending on your usage. Plug off the wall, refer to manual re. outlet filter. Siphon out maximum water by removing the tube from behind machine which goes into wall drain. (refit this after cleaning into EXACT position) Clean outlet filter and refit. Good luck.
When your outlet filter is clogged or blocked, the machine refuses to spin.
please rotate your cycle dial in the opposite direction of its usual motion by 90 degrees (probably counter clockwise). Then you can run the cycle again and the drain/spin/rinse should work. Otherwise, please power cycle your washing machine.
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart. 2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on 3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked) 4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down. 5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them. 6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher. 7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times. 8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was). 9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.) 10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty. 11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone! I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Keeping in mind that the soap & bleach gets dispensed into your wash on the
second to last rinse cycle and that most all rinse cycles are in cold
water. Is your cold water valve screen plugged causing your washer to
rinse poorly? Are you using the HE detergent? If not maybe the
washer is sudsing up to much and having a hard time rinsing all the
suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting
does it take a long time to fill the washer up? Also when it is full
and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of
the washer it might have a hard time draining out all of the soap
water before the next load
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
