Take my advice and call at the service centre for replacing a pull cord of Echo 400EVL.
Hi Joe,
Here are 3 links that may be helpful to you
https://www.manualslib.com/manual/453973/Echo-Cs-400evl.html
https://www.manualslib.com/manual/804151/Echo-Cs-400.html
https://www.manualslib.com/manual/41998/Echo-Cs-440evl.html
Best of luck,
JP
SOURCE: Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
Refill fuel tank with an 2-cycle Oli/gas mixture.
40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
Remove the spark plug.
Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
Remove the pull cord assembly (4-bolts)
This reviled the crank shaft-Pull cord bracket
I use a large monkey wrench to turn the shaft (CW) Clock-wise.
Complete approximate 20 revolutions.
Reassemble, but don't install the spark plug yet.
Complete approximate 20 more revolutions
by pulling the pull cord.
Use q-tips to swab the top of the piston, as much as possible.
Install the spark-plug and crank, it will smoke for amount 7-10 minutes
