SOURCE: moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
SOURCE: moen kitchen faucet spout
there should be a removable "button" on the faucet base below the handle. under there, there should be a set screw. loosen the screw, remove the handle. now u can adjust the base, collar, etc. to ur liking...don't forget to reassemble everything the same way u removed them.
Testimonial: "that was one reason I was looking for a diagram to show EXATLY how everything goes back !! will try your suggestion thanks"
SOURCE: Water Ridge Kitchen Facet with attached sprayer w...
You will ned to contact WaterRidge and have them send a Cartridge which you will have to replace. Their products are warrantied for life, so they should send it at no charge. The Customer Sevice # is 1-866-789-2273. You will need the Model # so they can send you the correct cartridge. I am trolling the web for replacement instructions, so I'll let you know if I find some.
