Question about Birds
How to stop air locks in my humming bird feeders
Humming bird feeder gets air locks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 93 Answers
Drill a 1/16" hole in bottom of feeder.
Posted on Jun 16, 2019
    Top Expert:
  • 85,222 Answers
Keep them clean.
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: Document feeder will not Operate
I am having the same problem with this scanner. Does the paper feed try tilt up? It does this to make the paper meed the rollers. Are the rollers moving when you try to scan? You could look where the edge of the paper meets the feeder, with a flash light or good lighting you could see if the rollers are moving. If not, and the belts for those rollers are on track. Remove the upper back cover. This only takes 2 screws. Once removed, you can tell the scanner to scan again, and see what part is not moving. The stepper motor engages, and spring moves, then another stepper motor engages and clutch should simultaneously move. More often than not, the clutch might have gone bad. I hope this info helps you trouble shoot your problem. With my scanner, I need to replace the clutch.
Posted on Jun 27, 2007
JayBlair
Jay Blair
  • 328 Answers
SOURCE: Brother Intellifax 4100 squeaky sheet feeder
The doc feed asm needs to be rebuilt. Only white lithium grease is used to lube the gears and avery light oil on the shafts. All parts are available from brother. I can get the parts if you have trouble obtaining them. It is relatively easy to rebuild and I charge in my area of Clearwater Florida, about 100.00 parts and labor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 01, 2007
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Posted on Nov 30, 2007
Anonymous
SOURCE: Brother MFC 8840, Document Feeder is not workting
ITS PROBABLE THAT A CONNECTOR CAME OUT.REMOVE BACK CORNER PANEL AT FEEDER CABLE TO CONFIRM.
Posted on Sep 11, 2008
ashburton
  • 417 Answers
SOURCE: Drill hole in China Plate
Normally you would use a masonry bit to drill into ceramics eg tiles or bricks. if the plate is glazed it is better to stick some masking tape or adhesive backed paper on the area to be drilled to stop the drill bit slipping around. also i would be inclined to use a hand turned drill or a small battery powered drill if you have one to avoid breakage of the plate.
Posted on Oct 13, 2008
I feed Humming Birds all year round. My question is during these hot dry months what do they eat when there are not any feeders? All local flowers and flowering weeds have long dryed out and died.
They come just after the spring flowers and stay with us until their food sources dry up. This is nature's signal to them that it is time to move on to a different climate., (South for the winter.)
They go to the tree tops and to the feeders of compassionate friends until cooler nights, shorter days and the last fall flowers signal it is time to go. (The birds that stop by your feeders on these evenings, probably are clutching little suitcases with their tiny feet.) Time to care enough to let them go be with their friends
Aug 24, 2018 | Garden
How hi should a humming bird feeder be?
Hi Andrew.
Hang the feeder approximately 5 feet above the ground, Make sure there is no foliage underneath that would encourage unwelcome guests, like mice, squirrels and even cats, to feed on the sugar water. If you wish to hang multiple hummingbird feeders, locate the feeders at least 10 to 12 feet apart.2.
read more at this link.
At What Height Should Hang Hummingbird Feeder Hunker
Jun 30, 2018 | Birds
No humming birds the kind that fly arround no moterized in texas
Hello, Mary -
You can find a recipe for making nectar to put in a humming bird feeder on the Hummingbird Society web site:
https://www.hummingbirdsociety.org/feeding-hummingbirds/
The information states "No red food coloring!"
Best wishes.
Apr 21, 2018 | Birds
I am trying to find out what kind of birds are coming to my feeder ,so I can buy the corrtect food for them.
lots of books world wide
on" local area bird identification "with pictures
librarys ,google images ,
"whats that bird " for example
RSPB What that Bird
Sep 20, 2016 | Whitehall Products Verdigris Hummingbird...
What is sugar to water ratio for humming bird feeder?
The overwhelming recommendation in the industry for making hummingbird nectar is a solution of 4 parts water to 1 partwhite table sugar (sucrose).
Source: Google Search for hummingbird sugar water ratio
Jul 12, 2014 | Computers & Internet
What are backyard birds?
Backyard birds are birds who visit your backyard. Which birds visit your backyard depends on where you live, the environment, and what foods may be available. Some birds will eat from feeders while, others only eat from the ground or from fruit/flower trees/bushes.
Several years ago, I created a wild bird garden for my mother in S. Florida. I have 20+ feeders, 3 water fountains, and a few trees/plants including, mango tree, hibiscus, berries, and more. We are visited daily by dozens of Monk parakeets aka Quaker Parrots, Blue Crown Parrots, Blue Jays, Cardinals, Doves, Cardinals, and more!
I can answer most questions about backyard birding (i.e.; foods, types of birds) for anyone interested in this hobby!
backyard-birds-zsfklhqbujkqzh40jobc00rz-3-0.jpg backyard-birds-zsfklhqbujkqzh40jobc00rz-3-1.jpg
Apr 28, 2014 | Birds
I have two humming birds this is october 25 do i still feed them they look cold
I feed them till they don't come around any more. Usually in the late fall. I live in southern Ontario Canada. Mine quit showing up when my red Cana Lilies died after first frost.
Oct 24, 2013 | Whitehall Products Verdigris Hummingbird...
In the beginning of summer I put up humming bird feeders with good results, will the humming birds continue to feed in the winter, I live in Alabama ?
If they don't migrate to florida , they remember where they have fed before and will return thru out the year...
Sep 08, 2013 | Birds
What does a suit bird feeder look like?
My birdloves eating from his suet bird feeder. Here is a picture similar to the onethat I bought
wtitsfhty1uaaaaasuvork5cyii=
Jul 24, 2012 | Birds
Feeding hummingbirds
they will migrate when it is time no matter if you feed them or not we have the same birds come back every year
Sep 12, 2009 | Humminbird Sport & Outdoor - Others
Birds Logo
183 people viewed this question
Top Birds Experts
Kardoc
Tom Chichester
NOEL
NOEL
Are you a Bird Expert? Answer questions, earn points and help others
