2001 Volvo S40 Logo
Posted on Aug 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 volvo s40 2.4i oil filter location - 2001 Volvo S40
Anonymous
Level 2:
Sniper:
  • Expert 60 Answers
  • Posted on Aug 27, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
60
Questions
0
Helped
38132
Points
138
Look down where the white circle is and you will see a black round casing with a 32mm (i think) nut on it. It helps to remove the air intake hose in front of the white circle for easier access.
5 Related Answers
Anonymous
  • 1392 Answers
  • Posted on May 12, 2009
SOURCE: location of volvo s40 2003 oil filter
It is underneath near the oil pan. Not really a filter, but the cover to the filter. Should be a black round looking thing. Remove this, and the paper filter element is inside. Be careful not to crack or damage the cover.
Anonymous
  • Posted on Apr 19, 2009
SOURCE: 2005 volvo s40 t5 how to reset oil light
turn the key on to position 1 preset miliage trip button anh hold for 2 second release and turn key to position 2 hold within 4 secods and hold til manitance info clears.
Anonymous
  • 42 Answers
  • Posted on Jul 19, 2009
SOURCE: Where is the fuel filter in a Volvo S40 2005
Yes that is correct. The only filter is inside the fuel tank, and as I recall its a non exchangeable filter. It just gets replaced with the fuel pump when it goes bad
Anonymous
  • Posted on Nov 13, 2009
SOURCE: oil filter location on a 2005 volvo v50 wagon
its an inline filter in a plastic housing in front of the engine
Anonymous
  • 31 Answers
  • Posted on Jul 04, 2010
SOURCE: how do you change the air filter on volvo s40 2005
under the hood towards the front of the car there is a rectangular cover, with 2 phillips screws holding it down. take out the 2 screws then you have to yank up on the cover cuz its usually pretty tight. then viola you have an airfilter
Where is the fuel filter in 2005 volvo s60
If you have a metal fuel tank there is no serviceable fuel filter as it is part of the pump.
Volvo S40 oil filter housing diaphragm
If you have 2005 T5 the oil filter is located exactly in the red car picture above. Except its not a 32mm socket, use a 36mm socket and a break bar. If you cannot do it with these tools bring it to someone who knows what they are doing. Its a simple operation.
3helpful
2answers
Where is the fuel filter on a 2005 volvo s40
There is no external fuel filter for this car. It is actually a fuel pump and filter assembly located in the top of the fuel tank. The genuine part number for the complete assembly is 30792725. It will also need the O'ring that sits below the assembly part number 8638939. This is straight from the Volvo Vida information... Hope This Helps.
1helpful
Where is the oil filter located on S40 Volvo, 2005
Under the intake manifold, behind the air cleaner intake hose (you must remove the hose).
2answers
Can you tell me where the oil filter is located on a volvo v50
the filter is a canister/element type meaning its not one you just screw on. with that in mind youre looking for a black round cover on the oil pan which be unscrewed and when you take it down you will see the filter inside. replace it and the o rings and refill the oil. the system will hold about 6 quarts.
1helpful
2answers
2005 Volvo S40 T5 is losing power while driving then suddenly regaining power. This happens over and over again.
had this problem as well.. check the oxygen sensor on it (sometimes critters like that wire) or like shel said dirty injectors or filters could be it.. bad gas is also another one... dont go to places with old tanks or that is really cheap, run at least 91
Oil filter location on a 2005 volvo v50 wagon
Is the oil drain plug and filter located under the plastic skidplate like guard under the car?
Yes. I beleive there are 4 bolts that hold this on. Also, the oil filter has a replacable element inside the outer plastic shell.
Oil change for 1999 Volvo XC90
on right side in that black cup by oil pan
Top Volvo Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Volvo Expert? Answer questions, earn points and help others
