SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
you can get the wheel here
http://www.amazon.com/Graco-Quattro-Deluxe-Stroller-Renaissance/dp/B000CEXO0C
Contact Graco directly...the will send out a free replacement wheel. The whole unit comes together and snaps on.
SOURCE: punctured tyre warning indicator
use the I drive system to reset flat tire monitor, go to vehicle settings, then flat tire monitor, then select reset, then you have to drive the car system resets as you drive
SOURCE: my john deere lt155 has a punctured tyre, how do i
in the center of the rim remove plastic cap remove c clip retainer then pull rim and tire off the machine
SOURCE: 2004 mitsubishi outander rear wheels tilting - extreme tyre wear.
Yes there is adjustment. You need to get the alignment checked out. It could be worn bushes and/or damage to the suspension linkages and struts.
