Seemed to proceed through bios screens normally; then the screen went dead. Can you suggest next step?
Hello Paul, sorry to hear about your problem with the ASUS, hopt that is the correct ID. I attach a link to an old webpage that talks about failed bios flash on that device. I am not certain that it is relevant but it appears so, hope it proves of use.If it does not, listing your device , searching for your device, and adding the phrase, 'bior recovery' might find you appropriate/helpful results. Good Luck.
https://hardforum.com/threads/tools-to-flash-and-recover-bios-on-asus-p8xxx-boards-fd44editor-ftk.1726429/
SOURCE: Bios update disaster
You have to download the old bios with another PC and then flash your bios with that.
Use this list to find your bios download depending on your video chip.
Worldvet
SOURCE: acer aspire 1640z bios update
That's a memory or RAM error. You need to re-seat the ram of your machine.
SOURCE: Pairing bluetooth motorola W755 phone to Garmin nuvi 760
I left the Garmin in passive mode and had just the phone do a search for new bluetooth devices and it worked fine. So my advice is , if the Garmin instructions don't work, try this method.
SOURCE: coating film on screen has a 'hole' after cleaning
Not panic!
I'm reading it and i did it again, to give you the advise. the plasma screen is glass that's sure, then:
The actual problem is really simple. because i remember my last jobs with plasma and this is actually a film protector the manufacture use when the part is not installed yet in the actual tv set.
SOURCE: The bios update failed on my 4g asus eeepc
What you need to do is to get the manual for the motherboard os you can reset the BIOS. On the other hand, you may not be able to preform that. This model is like a netbook and try this, remove the battery and the power cord. give it 15min. put the battery back in and reboot the system and than the power cord. that should help. if not, than a tech person is your next step.
