Button is missing from ignighter. is it necessary to get burners to light?
SOURCE: Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
SOURCE: When control knob in"pilot" position, burners light
It has a thermo-couple that lets the gas valve know that the pilot light is on. If it does not get the heat signal to the valve, it will not turn on the gas. The end of the thermo-couple has to be in the flame of the pilot, and tight on the other end, and must be tight on the other end.
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
SOURCE: burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
SOURCE: viking gas stove operators manual
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
