Called a repairman and and it was a waste of $$$. They said the control panel had to be replaced and they don't make that part anymore so I should purchase a new washer. The washer will still work, but is stuck on one cycle so I'd really like to fix if I can. I can buy a used control panel on ebay, but after looking at this more, I'm not sure that's the correct fix.Called a repairman and and it was a waste of $$$.
You can't post conmments that contain an email address.
Sounds like ur power on button may be shorted, u can check it with a multi meter, for continuity when pressing down it should show continuity. and none when released, To test it you can jumper the 2 wires together and see if it runs when plugged in? if not its ur push start button other wise I would think maybe the control board is bad
Without further information, I can offer three possible issues:
1. The fill value is furred up and is not fully closing (diagnose this by turning off the water after use at the isolator valve - and if no water is getting into the drum overnight, then it is a filling problem and you needn't read on - as opposed to a draining problem in which case read on!)
2. If you have a long drain hose running along the back of kitchen units, perhaps it is running back into the machine
3. Have you installed anything else into the same drainage pipes - such as a waste disposal unit or another appliance - that may be pushing water down the drain so fast, that some returns into other connected appliances?
Good luck
You need to offer more info for us to assist with possible fault.
When you say unplugging/re-plugging it allows it to work for a while, please explain - do you mean it works for a few minutes, it for a few hours or for a few washing cycles/days? Does it stop part way through a wash, or once started will it always finish a wash before failing again?
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk. Once emptied it worked a treat. Pull the flap down and turn the large knob anti-clockwise and pull to remove. Good luck.
Did you find out the fix to this? I have the same problem.
