Question about Fossil Watches
Hi i have fossil bq2273 i forgot to wind it and after i notice its no longer working i tried winding but still its not working. what should i do?
Anonymous
SOURCE:
Eric Mason
  • 161 Answers
SOURCE: how do i wind my
https://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
USE THE ABOVE LINK, SELECT YOUR WATCH FROM LIST. READ INSTRUCTIONS.
Posted on Nov 11, 2008
Anonymous
  • 26 Answers
SOURCE: My Fossil VT2657 no longer works.
it has a battrey or and atomatic winding gear. watch makers a stoped self winding watches due to people over windinfg and braking the watch. check battery it might be dead. or just shake the watch back and forth untill it starts again
Posted on Jul 13, 2009
Anonymous
  • 29 Answers
SOURCE: I can't get my head around how to manually wind my Fossil ME1020
You are not supposed to wind the watch, in simply winds itself with the motion of your wrist. A weighted wheel located in the back of the watch winds a spring that powers the second hand. The minute and hour is power by quartz and a battery.
Posted on Aug 09, 2009
Anonymous
  • 61 Answers
SOURCE: My watch no longer functions even after winding.
I have found that some of these "automatic" Fossils also contain a battery. That is how that provide an automatic watch at such a cheap price. I recommend taking it to a jeweler to have them check this. If it needs repair it will likely cost near the watche's replacement value.
Posted on Oct 17, 2009
Testimonial: "Thanks Admiral Adam, you provided some valuable insight into my problem"
Anonymous
SOURCE: Fossil AM-3662
It has a silver cell button battery, type 371 or equivalent.
Posted on Jan 27, 2010
Watch stopped working
Try winding it by hand. If it will wind manually and works then the problem is the 'winding mechanism' If it won't wind by hand then you need a watchmaker. Find one that is certified if possible, they are the most schooled.
Oct 08, 2012 | Fossil Ansel - ME3022 Analog Watches : One...
How to change the date on a fossil stella watch
For the single dial (winding crown). Pull out one click and this will change the date, pull out another click to change the time and keep winding forward or backward to get change the day and 24hour clock.
Feb 02, 2012 | Fossil Stella Topring Watch
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
Can't get back off to change battery, even with special tool
Looking at the Fossil site, I couldn't find "Arkitekt blue" as a description.
I noted that they have a blue one which is automatic (i.e. self winding) and therefore does not need winding - but it does need to be worn to keep the spring wound up.
The Fossil site has a complete list of their models and selecting one gives you all the details of the watch, including manuals.
I suggest you try a search on the web site.
Jan 02, 2010 | Fossil Arkitekt watch
Oct 16, 2009 | Fossil Batman Rotor Style Automatic...
My Fossil VT2657 no longer works. I can see no physical damage, but it hasn't been used in years. I'm not even 100% sure how to wind it, but after quite a bit of winding in both directions it still...
Jul 12, 2009 | Fossil VT2657 Pocket Watch
Apr 05, 2009 | Fossil ME1020 watch
Fossil AM-3662
Dec 10, 2007 | Fossil Watches
Watches Logo
98 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
Ray Murphy
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
