Car Audio & Video Logo
Paul Cullen Posted on Jun 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost power to the audio system in my 2011 Kia Forte I have check the fuses they all seem to be fine what am I missing?
Joe Stanton
Level 3:
Genius:
  • Master 1,154 Answers
  • Posted on Jun 05, 2019
Joe Stanton
Master
Level 3:
Genius:
Answers
1154
Questions
5
Helped
315642
Points
3584
If it is an aftermarket unit.....It may have a blade type fuse in the back of the unit.....most likely a 5 amp fuse.......
5 Related Answers
Anonymous
  • 776 Answers
  • Posted on May 31, 2009
SOURCE: I have no audio from my stereo
If you're not an electrician or a certified Hyundai Technician, find one. Let them diagnose the problem you described.
Anonymous
  • 720 Answers
  • Posted on Jun 08, 2011
SOURCE: what is p200a my check engine light is on 2011
I think the code you are referring to is P0200.
This code means your vehicle computer (PCM) has identified an issue within the Fuel Injector circuit.
Possible causes for P0200 code are:
  • Open or shorted injector
  • Injector low internal resistance (basically an injector that works, but is out of specs)
  • Grounded driver circuit
  • Open driver circuit
  • Driver circuit shorted to voltage
  • Wiring harness intermittently shorting against underhood components
Cheers,
sulavaca
Jamie Alton
  • 1007 Answers
  • Posted on Oct 30, 2012
SOURCE: radio not working on 2010 kia forte
The head unit has likely failed then in this case.
dpdmmoore
dpdmmoore
  • Posted on Jan 25, 2013
SOURCE: My 2005 Kia Amanti suddenly
I had to replace the amp which is in the trunk. Went to junk yard to get the amp and it took 10 minutes to replace. Worked fine. Stereo place wanted to charge $700.
Randy Ohler
  • 14585 Answers
  • Posted on Mar 06, 2015
SOURCE: does the 2011 kia forte have a history of front end rattles? brakes have been replaced
Things to check. sway bar bushings, sway bar links, lower ball joints, and struts.
Testimonial: "WILL TRY EETING NEXT WEEK"
I have a 2011 KIA Forte SX, the blower motor fuse blew and I swapped a few of the same fuses under the hood today
maybe you have mistakenly blew another fuse elsewhere , try all fuses with electrical tester.
Code P200A kia sorento 2011
It's a fault code connected with the intake manifold.
However, before you rush off and change it, have a look on the Internet. It seems that Kia had problems with this particular error code/or the software. Read about it first. Here's some links:
Check Engine Light P200A code intake manifold to be replaced Kia Forum
Check engine light code p200a 2011 Kia Sorento
Check Engine Light P200A code on new 2011 SX Kia Forte Forum Sedan Koup...
Engine cranks but no start
Check the fuel pump. Fuel pump relay. Car security system.
2helpful
2answers
Does the 2011 kia forte have a history of front end rattles? brakes have been replaced
Cheak lug nuts check CV joints check tires for were jack it up dose one wheel move more then the other when off the ground.
If you look close with it jacked up you will find something that is lose
2011 kia forte sx. Radio just quit now will not ev ed n turn on. Fuses are fine. Thanks g or the help but I fear that th ed rwdio is toast.
Check for the power supply ,in the back of the radio is two plugs ,one for the speakers and one with the power ,you should have two feeds one permanant 12v and one 12v through the ignition switch .then also check the earth as well or ground if your american
2answers
Why does the 2012 kia forte engine light turn on?
Engine Light Is On: 2010-2013 Kia Forte - What to Do - 2010 ...
www.carcarekiosk.com/...Kia_Forte_EX...engine_light/diagnose
A check engine light can indicate a broad spectrum of problems with your 2010 Kia Forte. ... The video above shows how to locate the on board diagnostics (OBD) plug on your 2010 Forte, how to read the trouble codes and how to reset or clear the checkengine light using a scanner on ...
KIA Check Engine Light (CEL) Codes - Kia Forte Forum : Sedan ...
www.forteforums.com/.../11832-kia-check-engine-light-cel-codes.html
May 20, 2012 - 15 posts - ‎8 authors
Old 05-19-2012, 08:42 PM Thread Starter. SketchedOut ... KIA Check Engine Light(CEL) Codes ... P0115 Engine Coolant Temperature Circuit Malfunction. 2012 Forte Koup: Check Engine light
Jun 29, 2015
Automatic Transmission Shifting Harder Than Usual
Apr 27, 2014
Check Engine Light + P200A code on new 2011 SX
Jun 7, 2011
Oil filter caused check engine light?
Where is the starter fuse located
Where is the starter fuse in a Kia Forte 2011. Car gets power but doesn’t turn over. Car initially died while driving on the freeway thought it could be the alternator and or battery. Put in new battery to boot cause it’s old but now it doesn’t turn over so I want to try the fuses before I move on to replacing expensive items.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
