SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
SOURCE: Fuel line size for troy built TB20CS weed eater
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
SOURCE: The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
SOURCE: I need to down load the ower manualfor troy bilt
here is the manual. Just click the file to download instantly.
1. 769-04481_TB539E_Operators_Manual.pdf
Please don't forget to give this answer a four thumbs up rating.
Thank you for using Fixya.
Alp
SOURCE: Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
