SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
SOURCE: circulation fans quit running after we shut down
check the door switches and see if they are engaging when the doors are shut. they are mounted just above each door. If just one is not being pressed in it will keep all of the inside fans off. also there is afan delay mounted by the inside coil that will keep the fans off until the coill cools to a certain set point to prevent recirculating hot air. depending on conditions it may take the fans a good 15 minutes to come on ,or longer in a very hot start up.
SOURCE: my upright freezer compressor is running but the
The problem is the evap. fan has gone bad. Part # WR60X10235, cost approx. $120.00 or the TJ90sm999 is one that will fit all of them which is only $25.00 and in my opinion a much better fan. Hope this helps. The sm999 has been around for years and is a universal fan which is easily adapted to fit all 115 volt evap fans like yours.
SOURCE: Model BHD-301 dehumidifier compressor will
Hi bash123er,
If you're facing these problem that your dehumidifier is not producing water and compressor is shutting off then there are few things that needed to be checked on:
1. The very common problem with most dehumidifiers is the circuit board relay. If this has gone bad then it will require replacement.
2. The compressor has already gone bad. This is the problem if you notice a buzzing sound every now and then from the system.
3. You may also have a refrigerant leak. This happens when the compressor is running but coils are not getting cold at all.
4. There will be cause of low water production if the fan is not running and the compressor does. If fan is not running then you have to replace it. This also will result frozen coil.
5. Check to see also if your coil is blocked. This will also result into no water production.Air needs to be continually moved over the cold coil to get the water out of the air.
If you're not comfortable doing the checking and repair yourself then I would recommend that you contact a repairman.
Hope this helps.
Thank you for using FixYa.
SOURCE: Cooling quit suddenly in both
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
