How to reset model F2-G? - Computers & Internet
    Habit-Forming:
  • 54 Answers
Who makes the "model F2-G" and what is it? Give details.
That is not found on Google search of whole Internet.
Posted on Jun 05, 2019
6ya staff
SOURCE:
Reset bios
  • Restart the system. Click on "Start," "Turn off Computer" and "Restart."
  • At the Dell loading screen Tap "F2" to enter the BIOS. "Entering Setup" will appear. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  • Once loaded, depending on BIOS version and type, you can reset the defaults by using "F9" key to Load Defaults, the "Load defaults" button on screen, or the "Alt" + "F" key combination to load factory defaults.
  • Press "Esc" on your keyboard and select save and exit.
  • Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your system to restart for the BIOS settings to reset.
Aug 30, 2013 | Dell Inspiron Computers & Internet
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Audible alarm sounded--"F2 "appeared on
Your model is actually a 911. Roper (Whirlpool)
The F2 error code is
E0 - Shorted keypad (also called touch pad)
E1 - Keypad cable unplugged
E5 - Cancel key drive line open
E6 - Cancel key drive line open
Solutions:
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 30, 2011 | Ovens
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Dehumidifier wont turn on or reset. code comes up as F2 and wont reset. Cleaned off filter. no help. any ideas you have would be appreciated.Just bought it last year. we have the hose connected to a...
To figure out what Code F2 is, I took a look at the Owners Manual for the Model # AD70USS, Strangely, the Owners Manual doesn't list an F2 Code or any codes for that matter. Because that model number humidifier, does not have an LED screen.
Never the less, to reset your unit using an alternate method. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and the dehumidifier should have reset itself. If it doesn't check the positioning of the water bucket, to make sure it's contacting the safety switch. Eventhough, you're using a drain home, it's still important.
Hope this helps you solve the problem.
May 08, 2011 | Whirlpool AD70USS Dehumidifier
How to reset bios my dell vostro 1500 . (11R50G1-595B)
To reset the BIOS please follow the below steps.
1 . Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
2 . Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
3 . Use the "Alt" + "F" key combination to load defaults.
4 . Press "Esc" on your Dell laptop keyboard to save and exit.
5 . Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
Thanks. Have a great day.
Dec 30, 2010 | Dell Vostro 1500 Notebook
F2 code on my whirlpool stove buttons not working.
The F2 could mean a timer/control has detected a stuck/shorted keypad. Depending on the model number though it could also mean a shorted oven temperature sensor.
In the event it is a stuck keypad detected, the timer or keypad will need to be replaced. You should first attempt to reset the breaker or unplug the range for a couple of minutes to see if that resolves the error code.
If it is the model that uses F2 as the shorted sensor code, you`ll need to replace the oven sensor, there`s no way around that one.
If you can provide a model number by replying to this post I could try and be more specific, as right now I can only generalize with the most common F2 error codes meaning for Whirlpool manufactured ranges/ovens.
Hope that help`s, let me know.
Good luck.
macmarkus :)
Dec 06, 2009 | Whirlpool 30" Freestanding Gas Range -...
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
EO F2 Lock message on oven panel
The solution was to hold down the "start" button for five seconds, which reset the system. I figured out that I had entered the model number of my oven wrong (mistaking a "Z" for a "2"). When I re-entered the correct model number in the "search for manual" section of the Whirlpool site, I was able to access the user manual and find the section that walked me through the correction.
Dec 29, 2008 | Ovens
Computers & Internet Logo
14 people viewed this question
Ekse
Marvin
Marvin
