Hi Petra, if the unit is not filling with water you most likely need a new fill valve. If it does fill with water and doesn't start to wash it could be a bad motor. Third option could be a bad control board/keypad,where it's not allowing the unit to cycle because it's not recognizing the command being input. Without the specific model number those are the top 3 common problems with dishwashers. Would call a local repair company to diagnose the unit and save yourself some headaches. Hope that helps.
SOURCE: Asko D1796 will not start properly
It sounds as if you may have A bad control board. It could be causing the heater element to come on when its not supposed to (usually a stuck relay) and not filling the machine with water. you could also have a bad control board AND a bad fill valve, as a stuck relay for the heater shouldn't affect the fill valve circuit. The bad news is that these asko control boards are $350 to $450 for just the part, the good news is that the control board is under a 5 year warranty (for only the part, not the labor to change it) as are the pump motors and any timers. Also, if you are just out of warranty, find your date of installation, as asko warranties start when you install it, not when you buy it (if you moved into the house and it was there when you moved in, and you are the first owner, submit a date of occupancy and that's when your warranty started)
SOURCE: Washer won't start
First of all, does the washer make a distinctive "click" when you push the START button? This is an indication that your door latch is locking (or at least making an attempt to lock). Normally, however, the display would have an "fdl" fault code indicating a door lock failure if it were bad. I have seen the latch go bad and not register a fault code, though. You can perform this simple diagnostic test to see if any fault codes register: 1. Select DRAIN/SPIN 2. Under SPIN SPEED select NO SPIN 3. Then, under OPTIONS push the PREWASH button 4 times. You should hear the door latch click then "C00" will show on the display. The washer will begin a series of tests (C01...C05 - depending on options and model) by testing the hot and cold fill valves, the various dispenser compartments, followed by tumble, drain and spin. If there is something wrong the diagnostic test will abort and a fault code will be displayed. The washer usually beeps when it displays a fault code. If you attempt to perform the diagnostic and the display momentarily flashes after you press the PREWASH button the fourth time and goes out, this can also be a symptom of bad door latch. You need to perform these simple steps first in order to further diagnose. Let me know what you come up with.
SOURCE: Washing machine.Fisher and Paykell Kelvinator
check the lid switch under the lower board they rust and the fault is normally not starting,or the display board can rust inside near the start/pause button if so try and unsolder a button you dont use and replace the start button.
SOURCE: GE Washer spin cycle not working
If your washer pumps out the water but doesn't spin, check these:
if this helps please vote me a fix ya
SOURCE: Pressure washer - no water flow
Is there a check valve on the hose inlet that is stuck, and won't let the water in???????
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing? This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent. Is "Sd" displayed and the wash cycle dial is not flashing? If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds. Is the drain hose kinked or clogged? Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work: NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
