If your coils are froze up, this could be temperature sensor I believe or your defrost valve, usually back in the fridge or your coils if they are frozen solid you need to unplug refrigerator freezer let it thaw out we will have lots of water so get towels and stuff to soak up your water once it is thawed frigerator freezer back in give it time to cool back down if the refrigerator side is cool now then I would say defrost valve or temperature sensor will need replaced there also should be a fan that blows the cold air into your refrigerator make sure that is working
One guess is there is no airflow thru the evaporator and is frozen solid.
Why no air flow?
Inside fan problem.
Check for your air damper openings make sure your freezer not freezing up and building up ice on the far back side Inside the freezer
Separate thermostat for fridge and freezer
SOURCE: WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
SOURCE: Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
SOURCE: GE side by side. Top shelf in fridge warm. bottom
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
SOURCE: hi i have a samsung
samsung fridge freezer problems
hi dont know if you have same model but this may help
