Question about Cuisinart Juicers
My cuisinart juicer its on whole the time how can i fix it? there is no switch, it does go on when you press down and off when you lift off
    Dedicated:
    Visited the website for 20 consecutive days.
  • 356 Answers
Your on off switch must be faulty
Posted on Jun 02, 2019
6ya staff
SOURCE:
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
I have a Homemaker HY5028. It's hard to clean it without taking the sieve out. Is it possible to take the sieve out without damaging it?
You need to use a knife or something to push down the small black release button then it will lift straight off. I got my daughter to push down the button as i lifted.
Aug 23, 2011 | Juicers
Doesnt turn on
unit must be fully assembled, then add fruit and press down with plunger
Jul 17, 2010 | Jack Lalanne Power Juicer 250 Watts
For an Oster Juicer Model 3165, how do I remove the stainless steel basket? Thanks.
Move from side to side and jiggle the whole assembly .. including the juice collector and juicing basket. With patience and even a break between attempts it will finally dislodge itself and lift up and off.
Just juiced carrots and a couple apples .. mmmm good ;-) best of luck
Aug 23, 2009 | Oster 3186 Citrus Juicer
No crescent tool included with purchase to remove the blade
Make sure the Juicer is unpluged. What you need is the cresent tool or two metal objects to place in the two holes opposite each other and press down the metal objects in the holes while turning counter clockwise. It kind of acts like a lock and key system.
Jul 28, 2009 | Jack Lalanne Power Juicer 250 Watts
HOW DO YOU take apart the jack Lalanne juicer blade and top unit to clean
LIFT UP AND SLIDE COVER RETAINING BRACKET OFF COVER, REMOVE COVER AND
PLASTIC NUT THAT HOLDS DOWN BLADE. ALL PIECES JUST LIFT OUT, BUT KEEP TRACK
OF THE ORDER THEY ARE REMOVED IN TO REINSTALL CORRECTLY.
Jun 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack La Lanne's Juicer
I removed mine by removeing the 3 screws on the blade
and lifting the whole filter out.
Feb 22, 2008 | Jack Lalanne Power Juicer 250 Watts
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
Juicers Logo
141 people viewed this question
Top Cuisinart Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Cuisinart Juicer Expert? Answer questions, earn points and help others
