SOURCE: craftsman garage door opener instruction manual
Have you tried the manufacturers site at either craftsman or sears. You should be able to find it there. You will need your model #.
SOURCE: PROGRAMMING IN CAR GARAGE DOOR OPENER TO GARAGE DOOR
Usually you just hold down the button in the visor, and while you're holding it down, aim your garage door opener at it and hold that button down so the frequency is grabbed by the built-in opener. That's how it worked in a few other cars that I've seen - try it out and see if it works for yours.
SOURCE: Need a user manual for mastercraft thickness planer
I'd suggest calling 1-800-689-9928 and speaking with one of the customer service representatives
SOURCE: garage door opener won't open garage door
did you use the manual release to unlatch the door from the opener? You may have a problem with the door binding and opening it manually will confirm that. You may also have misaligned the sensors at the base of the door so check that too.
SOURCE: looking for user guide for Mastercraft compound
Hope this helps, you need to call or email.
Contact Info
Phone
(305)392-2525
Fax:
(305)392-2590
Email:
[email protected]
[email protected]
[email protected]
Postal:
1354 NW 78th Ave. Miami, FL 33126
