Question about Onkyo Audio Players & Recorders
I have an Onkyo tx-nr807. It stopped putting out sound and where it shows all the speakers that are on, the subwoofer light is flashing. I have Martin Logan Electrostatic speakers and aML sub as well.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 130 Answers
" I have an Onkyo tx-nr807. It stopped putting out sound and where it shows all the speakers that are on, the subwoofer light is flashing. " If speaker indicators are on, you should check DIR and speaker relay drive voltage if +24V is present.
I have an Onkyo tx-nr807. It stopped putting out s - vlcsnap-2017-09-20-23h02m28s241-uiplbg2vipthdnz00ia54fqv-4-0.png
Posted on Jun 01, 2019
6ya staff
SOURCE:
Bruce Bennett
  • 9 Answers
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Posted on Aug 14, 2007
Anonymous
SOURCE: very low ouput from subwoofer preout
Onkyo to Onkyo, sub/receiver, problem fixed by inceasing volume on receiver. Seems the sub audio input does not pick up LF's below a certain output level from the receiver. So, guess I have to live with that. I only hope my nieghbor in the apartment below me can too!
Posted on Apr 29, 2008
maxchojinech
SOURCE: Onkyo 805 sub hook up problem
I made the same mistake when i hooked my REL sub up to the back of the 805.
The problem is there are 2 connectors on the back of the amp that are labeled as sub out. Look very closely, you will see that there are 2 grouped RCA outs. The RCA out group you are looking for differentiated by groups of "little white dots" all the way to the far right on the back of the amp. Hope this helps.
Posted on Jun 09, 2008
Anonymous
  • 17 Answers
SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Posted on Dec 16, 2008
Anonymous
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
How to run the speaker wires from the subwoofer to the onkyo 7.2 tx-nr626
See Onkyo manual here: http://filedepot.onkyousa.com/Files/own_manuals/TX-NR626_English.pdf
Insignia manual:
http://audio.manualsonline.com/manuals/mfg/insignia/nsht51.html?p=1
Best hookup method for sub is to use the LINE LEVEL INPUT on the Insignia, wired with RCA cables to the Subwoofer Pre Out jacks on the Onkyo
Jul 20, 2015 | Insignia NS-HT51 Speaker
Hi My Onkyo TX - SR875 has lost sound from Sub Woofer? not sure if the reciever or the Speaker? Any way to check? Martin
Hook the subwoofer RCA input cable to one of the other Pre-Outs. It won't sound GOOD but it will prove if the sub still works.
Then, if the Sub is alive, reconnect it to the Sub Out.
Get into the SETUP and make sure the Onkyo still knows you have a sub and do all the setup for the speakers.
May 03, 2010 | Audio Players & Recorders
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Jan 28, 2009 | Onkyo TX-8511 Receiver
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Subwoofer ... it is hooked up, but no sound
I found a manual online, and learned that there is a speaker set-up procedure on this Onkyo model ... so when it got to the subwoofer set-up, I simply went from "subwoofer off" to "subwoofer on"
Jul 25, 2008 | Onkyo TX-DS575 Receiver
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Mar 15, 2008 | Onkyo TX-SV545 Receiver
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
37 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
