Firearms Logo
Ronald Pratt Posted on Jun 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you reduce the trigger pull on a westernfield M72 the pull now is around 8lbs would like 5or6 lbs.
Steve Cox
Level 3:
Master:
  • Master 674 Answers
  • Posted on Sep 30, 2019
Steve Cox
Master
Level 3:
Master:
Answers
674
Questions
0
Helped
213233
Points
1718
Try your local gunsmith. Never attempt trigger work if you are not professionally trained.
While cleaning my creed i pulled the trigger. now can not get the slide back on. what do I need to do to re-set this?
Hello, Patricia -
See the slide stop instructions (3.2.3) in the user manual here:
https://www.waltherarms.com/wp-content/uploads/Walther-Creed-Instruction-Manual-r-a.pdf
(Page 13 of the manual) and try those steps.
If you still cannot get the slide back on, I suggest you take your hand gun to a local gunsmith for repair.
Note: On page 4 of the instruction manual there is a clear statement:
(Quote)
NEVER PLACE YOUR FINGER INSIDE THE TRIGGER GUARD OR ON THE TRIGGER UNLESS YOU INTEND TO FIRE.
(End quote)
Best wishes.
Jan 27, 2019 • Firearms
Setting double trigger on a cz rifle trigger
One of the triggers is the actual trigger, the other is the set trigger which lowers the trigger pull. The set trigger has a screw to adjust the sear and trigger engagement. Adjusting this by turning the screw inward reduces both trigger pull effort and the distance the trigger moves when pressed. I strongly urge that you either consult the manual for your rifle before making any trigger adjustments. If you are not confident you know what you are doing you should take this rifle to a gunsmith in your area for adjustment.
Jan 14, 2019 • Firearms
I have a H&R Topper and I want to replace the ugly plastic trigger guard and trigger group with blued steel. How do I install the trigger guard and group into the action?
The trigger is in a plastic housing that incorporates the guard, it is held in by pins, that must be driven out in the proper direction from the receiver. I would discourage you from doing this. The barrel latch has a heavy spring you will have to overcome in disassembly and reassembly and unless you know what you are doing you will need to hire a gunsmith to fix it. The better option is to spend your money on a better gun.
Dec 17, 2018 • Firearms
Trigger pressure adjustment for musgrave target rifle,how do you?
Musgrave triggers were set at 2 pounds pull weight at the factory. There are two screws with lock nuts on them in the trigger assembly but they only alter the engagement between the trigger and sear, effectively shortening the travel needed to release the striker. This does not lower the trigger pull weight. You have to remember that in a bolt action rifle, you are pulling against the firing pin spring which in some cases can be quite heavy in terms of compression rate of the spring. Since most modern rifles ship from the factory at 4 - 8 pounds of pull, your Musgrave trigger is pretty light at two pounds. Using this in competition requires a standard pull weight, and your job as the shooter is to keep the rifle sighted in through the pull of the trigger past where the weapon fires a cartridge. The follow through is nearly as important as the actual aiming of the rifle. My advice is learn to live with the 2 pound pull.
Jun 09, 2018 • Firearms
Model 2100 pellet rifle
This is a spring gun, and it uses a compressed spring behind a cup of leather in a cylinder to provide the pressure to fire. The most common failure is due to the cup drying out due to lack of oiling on a regular basis. once the cup dries out and hardens it shrinks and will no longer seal. Replace the leather cup/piston and it will work.
May 07, 2018 • Firearms
DAISY 415 [POWERLINE DOES NOT FIRE WHEN TRIGGER IS PULLED FIRES WHEN YOU LET OFF IT
It needs some adjustment, and not by you. This requires the skills and experience of a trained air gun tech. Find one by contacting Daisy.
Mar 15, 2018 • Firearms
DAISY POWERLINE 415 DOES NOT FIRE WHEN TRIGGER IS PULLED FIRES WHEN YOU LET OFF WHATS UP
This is probably due to a bad or malformed trigger. - contact Daisy to get it fixed.
Top Firearms Experts
vince
jws1013
Kolbrun...
Are you a Firearm Expert? Answer questions, earn points and help others
