Hi Cleopatra, e18 error code is a drain problem. Probably a sock or other debris clogging the filter. You can drain the machine by removing the access cover in front of the washer. using the small hose to drain any water into a shallow baking dish or use a wet vac to collect the water coming from the hose. Once the water has drained,lay a bath towel in front of the machine and slowly unscrew the filter and clean it out then put the filter back in and test the washer using a rinse and spin cycle. Don't forget to replace the plug in the drain hose before you start the test. Hope that helps.
SOURCE: My Siemens WM14S791ME Frontloading washing machine
F:23 means that there is a leak into the basepan of the machine and it should be checked by a competent repair person as sson as possible, the boby pin may have jabbed a hole in somthing or more likly there is a bad seal some were on the drum.
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
